Acousto-optic digital level detector circuit diagram
Source: InternetPublisher:难得正经 Keywords: Transistors power supplies and other power circuits Updated: 2020/05/12
The acousto-optic digital level detector circuit that will be introduced in this article is an acousto-optic digital level detector circuit composed of a 555 time base integrated circuit and a small number of peripheral components. The detector has good practical effect and is easy to make.
When probe A is floating, transistor BG is cut off, control terminal 5 of the time base circuit NE555 is at high potential, the controlled audio oscillator composed of NE555, R3, R4 and Cl does not vibrate, the speaker is silent, and pin 3 of NE555 The pin outputs a high level, and the LED is cut off and does not emit light, that is, the detector is silent and lightless. When probe A contacts the logic "O" level, pin 4 of the reset terminal of NE555 shows a low level, and the circuit is reset, so that the audio oscillator still does not vibrate and the speaker is still silent, but at this time, the output of pin ③ of NE555 is low level. flat, the LED is on and emits light, that is, the detector has light and no sound.
As shown in the figure, the probe A of the detector can be made by using a suitable copper wire. The transistor can be a 3DK3 or 3DK7 switch tube, the LED can be a red light-emitting diode, and the power supply can be a 6V laminated battery. All components are housed in a pocket radio case. When installing, pay attention to the location of the LED and speaker on the casing, and lead the probe and ground wire out of the casing.
![Acousto-optic digital level detector circuit diagram](http://www.eeworld.com.cn/circuit/upload/60ed1d9f807102346a78a304fe4a6dc6/45a44cc4fd694cb398b5d0120dc1c8c0.jpg)
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- 220V Remote Load Monitor
- Driving circuit of switching power supply field effect tube
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- LNK304 non-isolated LED light string driver circuit
- 3~15V 10A adjustable voltage regulated power supply
- Practical constant current charger-----Constant current charger
- MAX1811 Lithium Battery Charger Production
- A low-cost, high-reliability battery charger for electric vehicles
- 3V-5V level conversion circuit diagram
- Improved connection method of triode switch circuit circuit diagram
- Homemade C3355 transistor 1km FM transmitter circuit diagram
- One of the battery charge status indication circuits
- Improved multivibrator circuitb
- Soft start regulated power supply circuit three
- 95V, 100mA regulated power supply circuit
- Unijunction transistor wide pulse trigger circuit
- Cotton humidity detection circuit
