4kW single-phase AC voltage regulator circuit
Source: InternetPublisher:吃掉星星 Keywords: Power supplyAC/DC Updated: 2021/11/11
![4kW single-phase AC voltage regulator circuit](http://www.eeworld.com.cn/circuit/upload/c2cad2557fa7d907f374bf093b7c7a47/b4e8d5d75d55e66de0b6a6352c8f104a.gif)
The output capacity of this voltage regulator is 4kW, the output voltage is 0-210V, and the maximum output current is 19.2A. Voltage stabilization performance: The output voltage is in the range of 0~180V. When the power supply voltage changes ±5%, the output voltage changes ±1.5 V. Load impedance 110, ~5kfi, efficiency >98%. Load properties: resistive or inductive load with cos~p≥0.8.
The main circuit adopts a single-phase bidirectional thyristor voltage regulating circuit, and the trigger circuit is a single-junction transistor relaxation oscillator. The circuit is equipped with voltage negative feedback (Uf). The given voltage Ug is given by the master potentiometer RPi. Adjusting RPi can change the output voltage.
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- LED Driver ZD1680
- LNK304 non-isolated LED light string driver circuit
- A simple positive and negative power supply circuit
- CNC regulated power supply production
- Design of electric vehicle charger
- Production of backup power supply for cordless phone
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Homemade home inverter circuit diagram
- Principle of single live wire power taking circuit
- Sense amplifier circuit
- Two-wire remote AC electronic thermostat (gas or oil furnace control)
- Three-phase phase loss alarm light circuit
- Power circuit of STR5412
- Interface circuit diagram for controlling AC load
- 3v to 5v circuit diagram
- Power circuit of LBO-522 dual trace oscilloscope
- Timing switch AC power circuit
- Recording level power supply circuit
