Santana 2000 brake light and horn circuit diagram
Source: InternetPublisher:newlandmark Updated: 2021/11/11
![桑塔纳2000制动灯与喇叭电路图](http://www.eeworld.com.cn/circuit/upload/d627e245be0bc684b2735f61425c7745/2017517182427665688.gif)
Figure: Santana 2000 (gasoline injection engine) car brake light, horn, indoor light circuit schematic diagram
68 - brake linkage switch; 69 - brake signal light (left); 69a - brake signal light (right) 70 - horn relay;
71, 7a - horn; 72 - contactor between direction basket and combination switch; 73 - horn button; 74 - reading light;
74a - reading light switch; 75 - door control switch (right); 76 - reading light; 76a - reading light switch; 77 room control switch (left);
78 - sun visor cover lighting switch; 79 One sun visor cover lighting lamp; 80 one sun visor cover lighting switch. The
left width indication lamps 105 and 106 and the right width indication lamps 107 and 108 work simultaneously with the above-mentioned lamps, but the brightness cannot be adjusted.
The dimmer switch 109 is drawn from the second gear of the lighting switch 101, and the overtaking switch 109 is connected to the "x" column of the ignition switch, and
the high-beam filament flashes to indicate overtaking.
- DIY a practical audio-visual doorbell
- Smart car control system circuit design strategy
- Grain temperature measuring instrument circuit
- Disconnected anti-theft alarm circuit (1)
- Catillac luggage compartment closing circuit diagram
- HTS fire alarm
- stapler main circuit
- "Happy New Year" ring game console circuit
- Electronic ventriloquist circuit
- Light controlled electronic bird circuit
