Use 555 to make DC-DC boost circuit
Source: InternetPublisher:张三叔 Keywords: DC-DC boost circuit DC boost Updated: 2020/01/01
This circuit can achieve DC boost output and does not require a transformer. The 555 integrated circuit and R1, R2 and C1 form an astable multivibrator. According to the resistance and capacitance parameters in the figure, the oscillation frequency is about 5kHz. It is rectified by VD1 and VD2 and the voltage is doubled for output. If the input voltage VCC=12V, the output voltage is about 20V~24V, which varies depending on the load.
- Analysis of the working principle of switching regulator
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Build a simple buck-boost regulator and test it on a breadboard
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Basic connection circuit of signal and power supply composed of ISOll3
- Single-power supply circuit for ISO122P/ISO124
- Op amp power supply decoupling bypass measures
- Low cost and high performance LED constant current power supply
- Constant current charger using light emitting diode as voltage regulator
- Production of backup power supply for cordless phone
- Power circuit of STR5412
- Portable device charging power circuit design
- Power circuit b composed of intelligent thyristor modules
- Boost circuit
- transistor boost circuit
- SI9114 forms DC-DC typical application circuit diagram
- Boost circuit diagram composed of MAX660 and S81350HG
- Boost circuit diagram using MAX761
