Underarm odor treatment device circuit diagram
Source: InternetPublisher:刘德华河北分华 Keywords: Circuit diagram oscillator generator circuit Updated: 2021/09/04
Underarm odor is a product of bacterial mold. Ozone has the functions of sterilization, deodorization and mildew prevention, and its use in treating underarm odor has a certain effect. In this circuit, IC1 (M5232) forms a voltage detection and battery under-voltage automatic shutdown circuit. F3 and F4 form a 12kHz oscillator , which is modulated by the low-frequency oscillator composed of F1 and F2. Adjusting RP can make the working intermittent time continuous between 0 and 20s. Adjustable. When the battery voltage is greater than 4.2V, the LED lights up, pin 6 of M5232 outputs low level , the oscillation circuit starts to work, and drives the ozone generation circuit through V2 and V3 . When the battery voltage is less than 4.2V, pin 6 of M5232 outputs a high level , the oscillator stops vibrating and the ozone generating circuit is closed . At the same time, the indicator light flashes to remind you to replace the battery.
The circuit of the armpit odor treatment device is shown in the figure:
- How to improve SiC traction inverter efficiency with real-time variable gate drive strength
- Production of two-color music lantern
- Ray detection circuit
- Digital display time relay circuit
- Four water tower control schematic diagram
- Telephone cipher circuit
- EKG FM Demodulator Circuit
- Two-channel SL320 level indication circuit
- Blind electronic cane circuit
- Cadillac reversing light circuit diagram
- Wien bridge oscillator circuit
- High and low frequency signal generator circuit
- Transformer Oscillator
- Optocoupler controlled oscillator
- One of the simple second pulse source circuits
- Circuit of Multiple Groups of Colored Lights Chain with Flashing Cycles Part 7
- Use SGZ to make light-controlled automatic flashing lights
- Time base circuit AC dimmer circuit
- Refrigerator door opening alarm circuit
- Electrostatic spraying high frequency voltage generating circuit
