Simple and practical lithium battery charger
Source: InternetPublisher:傻阿乐 Updated: 2012/08/01
Brief description: Make a simple and practical lithium battery charger. Changing the 4 ohm resistor in the picture can change the charging current. D1 is the power indicator, and D2 is the charging indicator and current limiter. Simple and practical lithium battery charger Make a simple and practical lithium battery charger
by changing the 4 ohm resistor in the picture to change the charging current. D1 is the power indicator, and D2 is the charging indicator and current limiter. During debugging, replace the 6.8K resistor with a 10K trimmer resistor. Use a digital meter to monitor the battery voltage when it reaches 4.2V. Adjust the 10K trimmer resistor to
Latest Power Circuits Circuits
- Benefits of Wide Bandgap Technology for Power Converters
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Introduction and principle analysis of switching regulated power supply
- Basic circuit description of adjustable voltage regulator LM317
- Visible laser digital control modulation driver
- Simple and practical LED lamp driving circuit
- A simple positive and negative power supply circuit
- LM317 regulated power supply
- 3~15V 10A adjustable voltage regulated power supply
- MAX1811 Lithium Battery Charger Production
Popular Circuits
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
