Dimming and flashing dual-purpose socket circuit
Source: InternetPublisher:抄写员 Keywords: Lighting control Updated: 2012/11/29
Dimming and flashing dual-purpose socket This dual-purpose socket can perform stepless dimming of the lamp plugged into the socket; it can also make it flicker with adjustable flickering frequency, which can be used to enhance the indoor atmosphere. working principle
See Figure 1 for the circuit. When S is on, the circuit is a dimmer socket. The AC voltage is rectified by VD1-VD4 and becomes a DC pulsating voltage, which is added between the anode and cathode of VS. R1, R2, RP and C1 form a resistor-capacitor trigger circuit. When the voltage across C1 rises to a certain value, VS turns on and the lamp lights up. When the pulsating voltage applied between the anode and cathode of VS crosses zero, VS is turned off. Adjusting the potentiometer RP can change the charging rate of C1, which changes the conduction angle of VS, thereby causing the voltage at both ends of the bulb to change accordingly, achieving the purpose of stepless dimming. The voltage adjustment range at both ends of the bulb in this circuit is 150-220V, which meets the general indoor light dimming requirements. When S is closed, since the large capacitor C2 is connected, the circuit becomes a flashing circuit. Because C2 has a large capacity and takes a long time to charge, when the voltage across C2 reaches a certain level, C2 discharges to the VS control electrode through RP and R2, causing VS to conduct and the light to turn on. When the alternating current crosses zero, VS is blocked and the light goes out. C2 is recharged and forms ultra-low-frequency oscillation over and over again, and the lamp flashes. Adjusting the potentiometer RP can change the discharge rate of C2, which can change the flashing frequency of the lamp. The component selection and production component list is shown in the table below. No. Name Model Quantity R1 Resistor 100K 1 R2 Resistor 1M 1 RP Adjustable resistor 2.2M 1 C1 Polyester capacitor 0.047u withstand voltage >160V 1 C2 Electrolytic capacitor 10u withstand voltage >160V 1 VD1-VD4 Rectifier diode IN4007 4 SCR unidirectional controllable Silicon 0.8A/400V or more, such as 2N6565, etc. 1 S switch 1 RP is best to use a rotating shaft insulated to ensure safe use.
- A small improvement on the ordinary refrigerator motor starting circuit
- DC motor drive circuit composed of L293D
- Squirrel cage asynchronous motor reverse braking control circuit
- Simple phase failure protection circuit composed of intermediate relay
- Design and analysis of wire control circuit
- Hydraulic control circuit design and analysis
- Electric vehicle battery charging protection circuit
- PIC microcontroller controlled remote anti-theft alarm circuit
- A novel and practical power line anti-theft and cutting alarm circuit
- Homemade short circuit alarm device
- Homemade disinfectant circuit
- Rural fish farming control circuit
- Multi-channel patrol detection control circuit a
- Ringtone control circuit
- Switching regulated power supply circuit
- Infrared voice control circuit
- PLC light source robot hand bubble control circuit
- Automatic tuning control circuit
- Temperature detection control circuit of electric hot water bottle
- audio signal control circuit
