2×15W power amplifier circuit with fewer peripheral components (tda1521)
Source: InternetPublisher:Lemontree Keywords: Power amplifier circuit Updated: 2019/08/12
The high-fidelity power amplifier IC TDA1521A is used to make the power amplifier circuit. It has the characteristics of few external components, no need for debugging, and it works as soon as it is installed. Suitable for home-made, used for power connection of Walkman, or used to transform low-end computer active speakers. TDA1521A adopts a nine-pin single-in-line plastic package. It has the characteristics of high output power, small gain difference between the two channels, no impact sound when turning on and off the speaker, and reliable overheating, overload and short circuit protection. TDA1521A can be powered by either positive and negative power supplies or single power supply. The circuit principles are shown in Figure 1(a) and (b) respectively. When powered by dual power supplies, two audio output capacitors can be omitted, resulting in better high and low sound quality. When using a single power supply, the power supply filter capacitor should be as close as possible to the power end of the integrated circuit to avoid internal self-excitation of the circuit. During production, the integrated block must be equipped with a heat sink before it can be powered on for sound testing, otherwise the integrated block will be easily damaged. The heat sink plate cannot be smaller than 200×100×2mm3.
- Homemade high quality preamplifier tone circuit
- Preamplifier circuit made of composite screen triode electron tube 6C5P
- DIY 50W Gallstone Amplifier
- Make a pocket amplifier with 8550 and 8050
- 6N5P tube direct-coupled single-ended amplifier
- Design of a tube amplifier that uses the mains electricity to directly provide screen working power
- DIY a stylish Bluetooth speaker
- Dual power supply audio power amplifier circuit composed of LM3875
- Auxiliary audio power amplifier circuit using LM4732
- Protection circuit and maintenance of household audio power amplifier
- 175MHz high frequency power amplifier circuit composed of field effect transistors
- 50Wx2 high-fidelity power amplifier circuit
- Application circuit of LM3886
- 50W super class A power amplifier circuit
- Gentleman AM50 amplifier circuit
- High quality audio amplifier circuit
- Veuve Clicquot 4B7 radio OTL power amplifier circuit
- Making LM1875 DC negative feedback BTL power amplifier circuit
- High-quality power amplifier circuit of LF356+TDA1514
- Current pouring power amplifier circuit
