LCD TV power supply application circuit diagram
Source: InternetPublisher:常思一二 Keywords: lcd television lcd circuit power supply Updated: 2020/10/31
The PLC810PG combines PFC and LLC offline controllers with an integrated high-voltage half-bridge driver. Figure 1 shows a schematic diagram of the power supply structure using the PLC810PG device, in which the LLC resonant inductor is integrated in the transformer.
The PFC part of the PLC810PG adopts a universal input continuous current mode (CCM) design that does not require a sinusoidal signal input reference, thereby reducing system cost and external components.
DC-DC controller drives L LC resonant topology. This variable frequency controller allows the MOSFET to switch at zero voltage, thus eliminating most of the switching losses and improving efficiency. The core of the LLC controller is a current-controlled oscillator whose frequency control range supports the traditional operating frequency of the TV power supply.
In order to ensure zero-voltage switching, the dead time of the LLC switch in the PLC810PG is strictly controlled within the tolerance range and can be adjusted through an external resistor. The duty cycles of the high and low voltage ends are closely matched to provide balanced output current, thereby reducing the cost of the output diode.
A typical PLC810PG LLC design operates at 100 kHz (under rated operating conditions). Depending on the design of the LLC circuit, the switching frequency can vary from one-half to three times the rated operating frequency, which is related to input voltage and load changes.
The frequency of the PFC converter is locked to the LLC to reduce noise and electromagnetic interference. Increasing the PFC frequency in synchronization with the LLC at light load reduces the current drawn by the PFC boost converter when transitioning to discontinuous mode, thereby improving light load operation and reducing power line harmonics.
The design also provides PFC and LLC primary-side fault management capabilities. The PFC PWM output phase can be dynamically adjusted based on the LLC phase so that the switching edges do not intersect noise-sensitive portions of the PWM and LLC timing circuits. Edge conflict avoidance technology simplifies power supply layout and improves performance. Phase synchronization reduces EMI spectral content and ripple current in the PFC capacitor.
- Measurement and analysis of automatic emergency lighting circuit
- Design and production of a practical electronic counting device
- Low illumination amplifier circuit
- "OR" logic element configuration circuit
- Corridor automatic light-off device
- Microwave Doppler warning circuit
- Fluorescent lamp electronic ballast circuit 11
- Fluorescent dimming circuit (1)
- Four color light circuit
- Simple sensor alarm
- Provides USB Type-C® port chip solutions for lithium battery-powered devices
- The accuracy of DC-DC power supply is becoming more and more precise with the accuracy of FPGA.
- Regarding the power supply design part of DDR, it is worth collecting!
- What is a low EMI power supply? It’s worth collecting!
- As the leader in 65W power supplies, XPG CR650 power supply has been launched
- What is the difference between an adapter and a charger?
- The reason why the power supply should be set to +3.3V
- Power phase failure display circuit
- Automatic reset timer circuit
- AD594-595 functional diagram
