Metal halide lamp electronic ballast constant power control circuit diagram
Source: InternetPublisher:张三叔 Keywords: Constant power electronic ballast power electronic ballast metal halide lamp Updated: 2021/12/27
This circuit can increase the power factor λ of the system to above 0.99, effectively suppress the waveform distortion of the input power current in, reach the distortion index lower than L level required by GB15144, and ensure that the current crest factor of the HID lamp is less than 1.7.
Connect the detection resistor Rs in series to the input end of the Buck circuit, and then filter it through the resistor R1 to obtain the average voltage signal. The voltage signal of the lamp is detected from the L2 end. The two amplify the voltage signal through EA, and the output voltage obtained is used as a feedback signal. The relatively strong input is to the PWM controller, and the PWM controller outputs a control signal Vf according to the input feedback voltage signal to control the duty cycle of the switch S2 of the Buck circuit. By appropriately selecting R1, R2, and R3, the output power Po can be well controlled.
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Transformerless AC-DC constant current LED driver circuit
- Switching power supply circuit composition and function introduction of each part
- Parallel DC regulated power supply circuit diagram
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Charging control circuit made by solar energy
- UC3842 Electric Vehicle Charger
- Converting a lithium battery charging board into a constant voltage and current charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- A low-cost, high-reliability battery charger for electric vehicles
- Dual output electronic ballast circuit diagram
- Old 20W electronic ballast circuit diagram
- Fluorescent lamp electronic ballast circuit 12
- Fluorescent lamp high frequency electronic ballast circuit
- 40W fluorescent lamp electronic ballast circuit
- Electronic ballast circuit diagram using L6569
- Electronic ballast circuit diagram using ATT2161,2162
- Electronic ballast circuit diagram of 40W fluorescent lamp
- Overcurrent and overvoltage protection circuit diagram of electronic ballast
