Analysis of Motorola 168VA mobile phone car charger
Source: InternetPublisher:containsmachine Updated: 2018/06/21
There is a car charger on the market suitable for Motorola 168VA mobile phones. It is small and can be directly inserted into the car cigarette lighter socket for use or charging. Since the circuit diagram is not attached, maintenance is inconvenient. The measured circuit diagram is for reference during maintenance.
The UTC34063 in the picture is an eight-pin dual-in-line IC, which is a single-chip step-up and step-down DC conversion control IC. There are temperature compensator, comparator, high current output switch and other units inside the IC. The oscillation frequency is 100KHz. The actual measured data is shown in the table below. Pin number...on-circuit resistance value...voltage (V)...red test (KΩ) black test (KΩ) 1...4.1... .8.2 .......12 2 ......0.8...... 7.8...... 8.28 3 ......5.8 ......22 ... ....0.65 4 ....0 ...........0......... 0 5 .....1..... 1...1.26 6...4.2...8.2...12 7...4.2...8.2... ....12 8 .....5.......... 10 ....10.6 Note: (1) The on-circuit resistance is measured with a 500-type multimeter; (2) The voltage value is Input DC 12V, measure with DT890C+ digital meter in no-load state
![摩托罗拉168VA手机汽车充电器剖析](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d1ce9178-3c63-11ec-9aa0-086126841eb8.jpg)
Latest Power Circuits Circuits
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- 220V Remote Load Monitor
- Driving circuit that controls LED brightness using PWM signal
- Transformerless AC-DC constant current LED driver circuit
- LED Driver ZD1680
- A novel and practical DC low voltage stabilized power supply
- Homemade low-power UPS
- CNC regulated power supply production
- Electric bicycle battery charger circuit
- Homemade home inverter circuit diagram
Popular Circuits
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
