Home >
Power Circuits >Switching Regulated Power Supply > Two transistor, diode clamped single-ended forward converter circuit
Source: InternetPublisher:elleny Updated: 2015/05/11
The figure below is a two-transistor, diode-clamped single-ended forward converter circuit. VTl and VT2 are turned on and off at the same time by PWM pulse excitation. When they are turned off, the polarity of the voltage on N1 is reversed, diodes VD3 and VD4 conduct, and the potential is clamped. Therefore, the voltage amplitude applied between the collector and emitter during the cut-off period of VTl and VT2 is equal to the input voltage Ui.
Latest Power Circuits Circuits
- Build a simple buck-boost regulator and test it on a breadboard
- Fabrication of multi-cell lithium battery charging circuit
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Recommended circuits for different power on times of LM4911
- Transformerless AC-DC constant current LED driver circuit
- Principles and precautions of active discharge circuit
- LNK304 non-isolated LED light string driver circuit
- A novel and practical DC low voltage stabilized power supply
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Homemade home inverter circuit diagram
Popular Circuits
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
