Circuit diagram of small power transformerless regulated power supply composed of high voltage linear regulator HIP5600
Source: InternetPublisher:ohahaha Keywords: voltage regulator regulated power supply linear voltage regulator Updated: 2020/10/24
The precision voltage reference ICTL431 is in a T0-92 package as shown in Figure 1. Its performance is that the output voltage is continuously adjustable up to 36V, the operating current range is as wide as 0.1.100mA, the typical dynamic resistance value is 0.22 ohms, and the output noise is low. Figure 2 is a typical application of TL431, in which the output voltage V at both ends of pins ③ and ② is V = 2. As shown in the figure, a small-power transformerless regulated power supply is composed of a high-voltage linear regulator HIP5600. Its main features are as follows:
(1) DC working voltage can reach 400V;
(2) The effective value of AC working voltage can reach 280V;
(3) Connect two external resistors, and the DC output voltage can be adjusted from 1.2V to the input voltage VIN~50V; the output voltage is determined as shown in the table, and the output current can be adjusted from 1mA to 30mA;
(4) Self-installed radiator, thermal cutoff and output current limiting circuit in the chip, no need to set up external protection circuit.
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Practical and convenient fax machine power supply control circuit
- Recommended circuits for different power on times of LM4911
- Single-power supply circuit for ISO122P/ISO124
- Parallel DC regulated power supply circuit diagram
- Charging control circuit made by solar energy
- 3~15V 10A adjustable voltage regulated power supply
- Adjustable voltage power socket
- Circuit diagram explanation: simple switching power supply circuit diagram
- Design of adjustable DC stabilized power supply circuit module
- 3v to 5v circuit diagram
- Power circuit with smoothing filter capacitor
- Simple dual-channel variable DC power supply circuit
- Remote control TV doorbell power circuit
- Common power circuits and applications 09
- Common power circuits and applications 03
- AC-DC conversion power supply-inverter power supply circuit
- ±5V, ±12V power circuit A
- CTX-C2 dual-band high-resolution color display power circuit
