PC remote control circuit
Source: InternetPublisher:ohahaha Keywords: at89c2051 power communication power supply remote control Updated: 2020/05/14
The basic principle of the circuit is to collect infrared signals through the infrared receiver. When an infrared signal comes in, the microcontroller AT89C2051 software executes an interrupt and decodes the collected infrared signals, and sends them to the PC from the serial port. The PC software Girder receives the infrared signal from the serial port. characters and then make corresponding command operations according to the definition (for the basic usage of Girder, please see <Building a Super PC Remote Control>). A few simple components are used in the circuit to make a serial port power stealing circuit, so that the remote control does not need an external power supply and can be used just by plugging it into the serial port. It can be said to be plug and play :). After installation, after running Girder, the indicator LED1 will start to flash, indicating that the circuit is working normally. You can use your remote control at this time. When Girder is turned off, the power to the circuit board will be cut off and the indicator light will go out. The picture below is the complete electrical schematic diagram of this remote control receiver:
![PC remote control circuit](http://www.eeworld.com.cn/circuit/upload/6bda40ad492ab801bfd97e657de8a2f8/335f66be675249d0a1ee5571405b506d.jpg)
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- 5 Converter Topologies for Integrated Solar and Storage Systems
- A very convenient small power supply circuit to share
- Schematic diagram of car cigarette lighter to USB power port
- Driving circuit of switching power supply field effect tube
- Principles and precautions of active discharge circuit
- Power supply circuit that can reduce LM317 ripple
- Electric bicycle battery charger circuit
- UC3842 Electric Vehicle Charger
- LM317T voltage regulation adjustable circuit diagram explanation
- STR5412 power circuit
- Excellent performance household inverter power supply circuit
- Power circuit a composed of intelligent thyristor modules
- Typical Reference Voltage and Power Supply Circuits
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- Simple dual-channel variable DC power supply circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Common power circuits and applications 09
- High quality power supply circuit schematic diagram
