Audio control and soft-switching amplifiers
Source: InternetPublisher:酷到被通缉 Updated: 2017/12/11
The soft switching is enabled by a BD131 transistor wired as a switch in emitter follower configuration. The collector is wired to a permanent supply voltage, the 2H series inductor serves only to filter out power supply hum. This inductor is not too important and may be omitted if the DC supply is adequately smoothed. The control voltage is applied to the BD131 base terminal, the 10u capacitor and 10k resistor having a dual purpose:-
i) a gradual charge of the 10u capacitor ensures that the transistor will switch linearly from 0 volts to full supply, and
ii) serves as a hum filter ensuring a very smooth dc supply to the amplifier and tone controls.
LED1 will light when the amplifier is on. The control voltage should ideally be 0 volts when the amplifier is off and full supply voltage when on. The LM380 is shown driving two 8 ohm loupspeakers, the load is therefore 4 ohms. The 4u7 capacitor acts as a crude crossover, lower frequencies are impeded and so this loudspeaker may be a "tweeter" type.
- How about the boost converter TPS61299?
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Use pulse width modulation to get a precise output voltage
- Parallel DC regulated power supply circuit diagram
- Principles and precautions of active discharge circuit
- A small and easy-to-make fast charger
- Adjustable regulated power supply with current limiting protection
- 3~15V 10A adjustable voltage regulated power supply
- Car power 1.5V-12V six-speed converter
- MAX1811 Lithium Battery Charger Production
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
