IC card reader schematic diagram
Source: InternetPublisher:他们逼我做卧底 Updated: 2018/03/21
The picture shows the IC card and its reader/writer hardware circuit diagram. The reader/writer is composed of microcontroller, keyboard, display, monitoring circuit and other parts. The IC card uses X76F100Y of XICOR Company.
2.1 IC card and card holder
X76F100 is a 128×8-bit confidential serial FLASH E2PROM, in which the read password and write password are 64 bits respectively. Figure 2 is the pin diagram of its Smart Card package. Encapsulate the chip on a card, insert the card into the card holder of the IC card reader and writer, and the reader can read and write it to implement encryption, query, deposit, withdrawal and other functions.
The IC card holder has 8 pins, and when the X76F100Y is inserted, it is connected to these pins. There are also two fixed ends, one of which is connected to a spring leaf on the card holder. The two contacts and the spring leaf are equivalent to a normally closed switch. When the card is not inserted, the reed is closed and P3.2 pin remains low; when the card is inserted, the reed is pushed open and P3.2 pin becomes high level. When the microcontroller detects that the P3.2 pin goes high, it makes the RST pin of the X76F100 go high through P1.3 to reset it.
2.2 Microcontroller
The microcontroller adopts LG's GMS97C52. It has 8K bytes of ROM, 256 bytes of RAM and 32 I/O ports. The P1 port is connected to the serial devices X25045 and X76F100. The P0 and P2 ports are used for keyboard and display. P3.2 in the P3 port is used for Detect whether the IC card is inserted, and the remaining 7 ports can be expanded with other functions.
2.3 Monitoring circuit
The monitoring circuit uses the X25045 chip, which includes a watchdog timer, voltage monitoring circuit and E2PROM memory. Its function is: generate RESET signal to GMS97C52 when power is turned off; watchdog monitors the system to prevent crash.
2.4 Keyboard circuit
For convenience, the keyboard interface circuit is implemented with an I/O port, which has a 4×4 structure and 16 keys. There are 11 numeric keys, 4 function keys, and 1 enter key.
Numeric keys: 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, ← (backspace).
Function key: Query? , Store+, Withdraw-, Change Password*.
Inquire? : Users can check the amount deposited in the card by reading the password.
Deposit+: Users can deposit money into the card by writing a password.
Withdrawal -: Users can withdraw money from the card by writing the password.
Change password*: divided into changing read password and writing password. For convenience, let the read password and write password be the same
Please press this key to change the read password and write password at the same time.
Enter key: Confirm after entering the 8-digit password or the amount of deposits and withdrawals, and confirm after entering the new password.
2.5 Display circuit
The display part uses an LED display and is also implemented with an I/O port. Used to display system status, entered password or amount to be deposited and withdrawn, as well as error messages, etc.
Since the driving current of GMS97C52 is limited, inverter SN74F04 is added to the P0 and P2 ports to increase the driving capability. Its sink current is 64mA and its output current is 15mA, which can ensure the sink current required for bit selection.
- Design and production of voltage regulator for YAMAHA motorcycle
- PS10, 702F, WT020 physical color picture 1
- 845ddr computer motherboard circuit diagram_14
- Computer motherboard circuit diagram 430TX_20
- Computer motherboard circuit diagram 810 3_13
- Computer motherboard circuit diagram 820 2_35
- 875p computer motherboard circuit diagram_089
- Computer motherboard circuit diagram 440LX_01
- Thermocouple AD conversion circuit
- Computer motherboard circuit diagram 830_54
- Hisense Plasma TPW4218P Power Board Principle and Maintenance (Samsung V3 Screen Power Supply) - Home Appliance Repair
- Konka LC-TM2620 LCD TV black screen-Home appliance repair
- Hisense LCD TV TLM46V86PK sometimes makes strange noises when it is turned on, and the screen displays problems when it restarts - Home Appliance Repair
- Hisense LCD TV 42K431DX4F automatic shutdown fault repair example - home appliance repair
- Hisense LCD TV TLM42V78K crash repair example - home appliance repair
- Hisense TLM36H48 LCD TV has dark white raster and no image - Home Appliance Repair
