Voltage dividing self-bias circuit
Source: InternetPublisher:三岁就很酷 Keywords: Power supply other power circuits Updated: 2021/04/29
![Voltage dividing self-bias circuit](http://www.eeworld.com.cn/circuit/upload/2be708836f92a0c6ee61033ed7df6bec/5782f650dc5929c4d036f68cb1f2d2d1.gif)
The figure above shows a voltage-dividing self-bias circuit, also known as a gate-connected positive potential bias circuit. It is based on a self-biased common-source amplification circuit and is composed of voltage-dividing resistors R and R. In the figure, the power supply UDD, input coupling capacitor cl, output coupling capacitor C2, drain resistor R, source resistor Rs, source bypass capacitor C; all have the same function as the self-biased common source amplifier circuit. Rti and R丶 are voltage-dividing bias resistors, and the contact point between Rn and R is connected to the gate through a large resistor Rf. Since there is no current in the gate insulation, the voltage dividing point A of Rn and R is at the same potential as the gate. Since this circuit has both "voltage division bias" and "self-supply bias", it is also called a group bias circuit. This bias circuit can be used for depletion mode field effect transistors or enhancement mode field effect transistors.
- Benefits of Wide Bandgap Technology for Power Converters
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Energy-saving motorcycle rectifier regulator
- Basic connection circuit of signal and power supply composed of ISOll3
- Visible laser digital control modulation driver
- Adjustable regulated power supply with current limiting protection
- Power supply circuit that can reduce LM317 ripple
- Electric bicycle battery charger circuit
- UC3842 Electric Vehicle Charger
- A low-cost, high-reliability battery charger for electric vehicles
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
