Headphone amplifier circuit diagram based on NE5532
Source: InternetPublisher:张小哥 Keywords: Power supply other power circuits Updated: 2021/06/17
E5532 is generally used as a preamplifier with excellent performance. Now used as a low-power power amplifier, what is the effect? It is almost the same as a general op amp circuit, but the resistors and capacitors have changed greatly, and the working state is different from that of the op amp circuit. Experiments have proven that NE5532 can be used as a low-power amplifier with excellent performance.
In order to listen to CDs (VCDs) with headphones, I only spent more than thirty yuan to install a high-fidelity headphone amplifier with beautiful sound quality. NE5532 is generally used as a preamplifier with excellent performance. Now used as a low-power amplifier, what is the effect?
A quick look at the circuit schematic shows that it is almost the same as a general op amp circuit, but the resistors and capacitors have changed significantly, and the working state is different from that of the op amp circuit. Experiments have proven that NE5532 can be used as a low-power amplifier with excellent performance. Beginners may wish to give it a try.
The following points should be noted during the trial production process:
1. If the power supply filter capacitors C9 and C10 are used too small, they will cause self-excitation. When used as a preamplifier, 100μF for C9 and C10 is enough, but when used as a power amplifier, it must be increased to more than 470μF. At the same time, the filter capacitor is directly related to the sound quality.
2. The resistance values of R4 (R9) and R5 (R10) in the circuit should be adjusted repeatedly. In the preamplifier circuit, R4 (R9) is generally 1KΩ, while R5 (R10) is 100KΩ, so its amplification factor can reach 100 times. But now when making a power amplifier, self-excitation will occur, so R4 (R9) is changed to 8.2K, and R5 (R10) is reduced to 33K. The amplification factor is only 4 times, and the circuit will not be self-excited. At the same time, the negative feedback is appropriate and the sound quality is improved. Soft, clear and highly transparent. If R5 (R10) is further reduced to 15K, the negative feedback will be too deep, not only the volume will become lighter, but the tone will be dull. Readers can debug it repeatedly to achieve perfection.
3. C2 (C6) is the ground path of the input circuit. It is only 10μF in the preamplifier circuit. When used as a power amplifier, the input impedance is too large, blocking the signal, causing distortion or even self-excitation. Now increase C2 (C6) to 100μF, the sound quality is significantly improved, the range is broadened, the treble is crisp and sweet, the midrange is pure and bright, and the bass is deep and rich.
4. The power supply of this machine can be selected from 3V~15V. You can use four batteries connected in series to form a bidirectional (positive and negative 3V). The volume is not much different from that of 12V, but the sound quality is not as good as 12V. It is recommended to use 9V~12V.
In addition, the input end is connected in series with R1 (R6) 51K because the volume is too high when listening with headphones. If R1 (R6) is removed, a small speaker of less than 5 inches can be connected, and the listening effect is also very good in front of the desk or at the bedside.
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Detailed explanation of 5v charger circuit diagram
- Switching power supply circuit composition and function introduction of each part
- How to use SBR to improve power conversion efficiency
- LNK304 non-isolated LED light string driver circuit
- Current/voltage conversion circuit using current converter
- Miniature polarity reversal power supply using MAX1721
- 0.7~24V continuously adjustable current limiting power supply
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Detailed explanation of mobile phone charger circuit diagram
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
