Do you know about the new automotive-grade EMI suppression film capacitors?
Source: InternetPublisher:张七岁 Keywords: Capacitor f339x2 305vac Updated: 2020/11/26
Do you know the new automotive-grade EMI suppression film capacitor? What does it do? November 28, 2018 - Recently, Vishay Intertechnology, Inc. (NYSE stock code: VSH) announced the launch of the new F339X2 305VAC series automotive-grade X2 electromagnetic interference ( EMI) suppression film capacitor, the device is qualified for jumper circuit applications (50 Hz / 60 Hz) and is AEC-Q200 (Revision D) and IEC 60384-14: 2013 / AMD1: 2016 Class IIB certified.
In accordance with the new humidity level standard defined by IEC 60384-14: 2013 / AMD1: 2016 IIB level, Vishay BCcomponents F339X2 305VAC series capacitors were subjected to 500 hours of accelerated temperature and humidity testing at a temperature of 85 C, a relative humidity of 85%, and a rated voltage of Bias test (THB), capacitance value and loss coefficient are extremely stable, thus proving extremely high reliability and longer service life under harsh application conditions.
The devices announced today can be used as EMC filters in automotive and industrial power inverters. Capacitor pin spacing is 15 mm, 22.5 mm and 27.5 mm; capacitance values are from 0.1 μF to 4.7 μF with tolerances as low as 10%; DC voltage is allowed in the range of 630 V.
The F339X2 305VAC series capacitors are packaged in an epoxy resin sealed flame retardant UL-class 94 V-0 plastic housing. Lead (Pb) capacitors are RoHS compliant. The above is the analysis of the new automotive-grade EMI suppression film capacitors. I hope it can be helpful to everyone.
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Basic connection circuit of signal and power supply composed of ISOll3
- Transformerless AC-DC constant current LED driver circuit
- Simple and practical LED lamp driving circuit
- Low cost and high performance LED constant current power supply
- A novel and practical DC low voltage stabilized power supply
- LM317 regulated power supply
- Car power 1.5V-12V six-speed converter
- Homemade Electric Bike Fast Charger
- Detailed explanation of mobile phone charger circuit diagram
- Do you know about the new automotive-grade EMI suppression film capacitors?
- Bypass capacitor welding analysis
- Switching power supply circuit composition and detailed explanation of each part (1)
- STR5412 power circuit
- Power supply circuit design optimized for digital light projectors
- Portable device charging power circuit design
- Transistor recording signal amplification circuit
- Power circuit with smoothing filter capacitor
- Three-way DC-DC converter circuit
- 2-phase CPU power circuit using HIP6302 and HIP6601 chips
