Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
Source: InternetPublisher:fish001 Keywords: frequency band integrated amplifier amplifier circuit BSP Updated: 2021/05/23
The common-emitter common-base wide-band amplifier circuit composed of the F733 integrated broadband amplifier has small internal feedback, strong amplification capability, and good circuit stability.
It is a commonly used amplifier circuit. ' The
cascode-common-base broadband amplifier circuit composed of F733 integrated broadband amplifier is shown in the figure.
Integrating a broadband cascode and common-base integrated circuit and changing the negative feedback resistance of the first-stage differential amplifier can adjust the voltage gain of the entire circuit.
Short-circuit the terminals ⑨ and ④, and the gain can reach 120dB. Short-circuit the terminals ⑩ and ③, and the gain can reach 40dB. If the terminals are not short-circuited, the gain
will be ZOdB.
The upper frequency limits in the three cases are 40MHz, 90MHz, and 120MHz.
- Transmitter Receiver Circuit for 80 Meter Amateur Radio
- Application of GaN power devices in array radar transceiver systems
- Design and Analysis of Half-duplex Intercom Circuit Using LM386
- MICRFl04 ASK 470~300 MHz Transmitter
- GPS RF front-end circuit composed of MX2740
- TXl00 ASK 1 GHz~100 MHz transmitter module
- rfPICl2C509AG/509AF ASK/FSK 480~310 MHz with 8-bit microcontroller transmitter
- RXM-433/418/315-LC-P AM Receiver Module
- CYWUSB6932 GFSK 2.4 GHz Wireless USB Interface Transmitter
- RF2516 AM/ASK/OOK 433/315 MHz Transmitter
- electromagnetic field sensor
- stuttering correction circuit
- Smoking Cessation Circuit
- Rice mill circuit
- Soil water shortage prompt circuit
- Diode square rate detection circuit
- Series crystal oscillator
- OTL low frequency power amplifier circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Three primary color display circuit
