Wall wire detection circuit
Source: InternetPublisher:睡不醒的小壮 Keywords: Detection circuit LED gate Updated: 2021/04/27
This is the electrical schematic diagram of detection only. TX is a sensing piece, which induces an AC signal near the AC wire and sends it to the gate
of
the junction N-channel field effect transistor VT1 . VT1 has half-wave rectification and amplification effects on AC signals. When there is no signal,
the drain of VTI outputs high level , and VT2 and VT3 are both cut off. The LED doesn't light up.
In the negative half cycle of the signal. Make the gate of Tl more negative relative to the source. So
the VT1 output is still high level. L.ED does not emit light; and when the signal is in the positive half cycle,
VT1 outputs low level , and VT2. VT3 is turned on and the LED lights up. R2. R3 and e
add bias voltage to VT1 to improve the sensitivity of detection.
- Simple and practical EPROM detection circuit
- Temperature Range Monitoring System
- A highly sensitive human proximity detector
- Circuit Fault Tracker
- Using a Remote Control to Make a Crystal Oscillator Frequency Tester
- How to Use a Radio as a Metal Detector
- DT8 type 5A current mutual induction three-phase four-wire active energy meter wiring
- AC equivalent amplifier circuit
- Geiger counter circuit diagram
- Temperature voltage conversion circuit
- SG1524 driver LED circuit
- Ambulance electronic flash signal circuit diagram
- LT3755 driver LED application circuit diagram
- Ordinary optocoupler isolation circuit
- Three-phase phase loss alarm light circuit
- Working principle of single touch mode light switch
- Simple light-emitting display logic pen circuit
- The equipment runs through Chengdu display circuit
- Three-phase alternating current detection circuit
