Grain moisture detector circuit
Source: InternetPublisher:走马观花 Keywords: detector plate capacitor Updated: 2021/01/06
During the grain purchase season, the grain management department has certain requirements for the humidity of grain. At present, many places still use the simplest method of touching and biting the teeth
to judge the moisture content of grains, but its accuracy is poor. Using the grain moisture detector as shown in the figure can quickly, accurately and intuitively give
the humidity of the measured grain. Its working principle is based on the fact that the capacitance of a plate capacitor is related to its dielectric. Two copper plates with the same volume and a fixed distance
form a flat capacitor. When granular grain is placed between the two flat plates of the flat capacitor , the medium changes from air to granular objects,
causing changes in dielectric loss and electric current. Capacity increased.
The oscillation frequency of the multivibrator composed of 555 timer also
changes accordingly. Differences in grain humidity will also cause
changes in the oscillation frequency. The rectified DC voltage also
changes accordingly. In this way, the humidity of the grain is converted into DC
voltage and is indicated by the DC voltage.
The capacitance of the flat capacitive sensor should change by 1OFrF,
and the DC voltmeter will indicate a change of 2V. As long as
the humidity indicator or the qualified red
band is engraved on the DC voltmeter, you can easily measure whether the humidity of the grain is qualified
. RP is the zero adjustment potentiometer.
- How to test whether the multimeter is working properly
- A highly sensitive human proximity detector
- Level measurement circuit composed of AD737
- Digital strain gauge circuit using MAX1492/MAX1494
- Homemade LED digital display photovoltaic meter
- Transistor reverse breakdown voltage tester-----Transistor tester
- 1.5V and 9V battery tester circuit diagram
- An electronic load meter using LM324 operational amplifier as the main control device
- Production of acoustic and optical digital level detector
- Sample and hold circuit diagram
- Humidity detector circuit diagram
- Level detector circuit diagram with hysteresis
- Audio decibel level detector circuit diagram with instrument driver
- Micropower radiation detector circuit diagram
- Peak Detector Circuit Diagram
- Window detector circuit diagram B
- Liquid level detector circuit diagram
- Dual-level detector circuit that accurately determines "pass" or "fail"
- Gas and smoke detector circuit diagram
- Battery Powered Ionization Chamber Smoke Detector Circuit Diagram
