EL-700 (100Ω) platinum resistance temperature measurement circuit
Source: InternetPublisher:走马观花 Keywords: Platinum resistor temperature measuring circuit BSP Updated: 2020/06/07
This is a temperature measurement circuit using EI: 700 (lOOn) platinum resistance . The temperature measurement range is +20~+120℃, and the corresponding
output is 0-2V. The output voltage can be directly input into the microcontroller for display and control signals (if the microcontroller does not have an A/D converter, it needs to go through
5G14433 before inputting A). .
The platinum resistor is connected to the measuring bridge. In order to reduce the measurement error caused by too long connecting wires, a three-wire system is adopted. The signal is amplified by Al
, and the amplified signal is filtered out useless clutter through a low-pass filter composed of A2.
A standard resistor box is used in place of the sensor during adjustment. When £=20℃, adjust RP1 to make the output Uo-ov; when -120℃, adjust
RP2. Make U. -2,ov.
If lkfl platinum resistor is used , 8.2kfl should be changed to 18kfl, and 20kfl should be changed to 68kfl. RP1 is changed to ZkSl potentiometer.
- Multimeter with small capacitor test circuit
- Electromagnetic radiation monitor
- Detection of Bidirectional Trigger Diode
- Level measurement circuit composed of AD737
- 3 1/2, 4 1/2 digit intelligent digital voltmeter circuit composed of MAX1492/MAX1494
- Inductive Pointer Watch Battery Tester
- Four logic probe circuit diagrams
- Production of acoustic and optical digital level detector
- AC ammeter circuit
- High Performance Digitally Controlled Amplifier-Gain Divider
- Set timing circuit when power is on
- Excellent performance household inverter power supply circuit
- Electric massager circuit
- Agricultural temperature control circuit
- Agricultural small tractor lighting circuit
- Poultry warming temperature control circuit
- Farmland irrigation automatic control circuit a
- Proportional frequency discriminator circuit
- Wien bridge oscillator circuit
- Broadband high frequency power amplifier circuit
