Pressure measurement circuit diagram
Source: InternetPublisher:张七岁 Keywords: Circuit diagram pressure measurement circuit BSP amplifier Updated: 2020/03/03
It is a measuring circuit, when the force is 0~1500g. U. Output 0~1500nN (sensitivity ImV/g). The power supply is powered by
±12V, and the force sensor is powered by 12V (about 10V) after being stepped down by three diodes. A1~A3 form an instrument amplifier , and its differential input
terminal is directly connected to the ② and ④ pins of the force sensor. A4 is connected as a follower, and the voltage of the potentiometer RP2 is input. Its function is to eliminate the zero point output,
that is, when the force is zero, if the bridge has an unbalanced output or the amplifier has an offset voltage, RP2 can be adjusted. Make the output U. -ov. Adjust RP1
(magnification adjustment) to make Uo =1500mV when the full-scale force is 1500g.
In order to ensure the accuracy of the instrument amplifier , the resistors should be metal film resistors. The accuracy of the resistors in A1 to A3 is 1% or matched.
- How to measure short circuit and ground with a multimeter
- Balcony intelligent invisible anti-theft net
- New function added to MF-47D multimeter - infrared remote control detection
- Analysis of valid and fault conditions of differential signals
- Simple and easy to make zero degree detector
- AC ammeter circuit
- voltage amplifier circuit
- High-speed gain programmable amplifier circuit
- Three-phase three-wire active energy meter connected to three ammeters
- DS8 type 100V, 5A mutual inductance three-phase three-wire electric meter wiring
- Smoking Cessation Circuit
- Physiotherapy ventilator circuit
- Peanut and melon seeds roasting machine circuit
- Rice mill circuit
- Farmland irrigation automatic control circuit b
- Proportional frequency discriminator circuit
- Second-order active band-stop filter circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Three primary color display circuit
- Sawtooth wave generator circuit (2)
