DC resistance measurement circuit
Source: InternetPublisher:通通 Keywords: Resistance measurement DC resistance measuring circuit BSP Updated: 2020/11/24
When the transfer switch is placed in the resistance measurement position, its circuit composition
is as shown in the figure. The ohmic range of the 500-type multimeter uses
a voltage-dividing zero-adjusting resistor. The ohmic
center values of each range from ×1 to ×lOk are iori, ioon, lktl, lOkn, and
lOOkil respectively. For example, in ×l gear, the ohmic shunt resistance is 9.4n, plus
the internal resistance of the battery is about 1n. And considering the parallel connection with other circuits
, the effective internal resistance of this gear is 10S1. Therefore the center ohms
value is also 100.
×iok high-resistance gear, the battery voltage is 1-5V-1-9V,
and the shunt resistor is removed, and an 85.2kfl
resistor is connected in series, so the central resistance is 100kfl.
It can be seen from the above analysis that as the ohmic range
increases, in order to prevent the sensitivity of the meter from being affected,
dual measures are taken to increase the battery voltage and line sensitivity.
- How to test whether the multimeter is working properly
- Lightweight and practical multi-core cable detection circuit
- New function added to MF-47D multimeter - infrared remote control detection
- Isolated 4-20mA instrument loop (RTD) circuit composed of RCV420
- Analysis of valid and fault conditions of differential signals
- Design of wireless meter reading system based on DSP
- Design of blood analyzer
- Using a Remote Control to Make a Crystal Oscillator Frequency Tester
- Simple password electric lock
- 3W portable megaphone circuit
- Excellent performance household inverter power supply circuit
- Inpatient pager circuit
- soil content measurement circuit
- Particle clogging alarm circuit of wheat seeder
- Soil water shortage prompt circuit
- Frequency modulator composed of NE566
- collector amplitude modulation circuit
- Audio function generator composed of ICL8038
- OTL low frequency power amplifier circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
