Inspection of vertical air deflector drive motor and circuit
Source: InternetPublisher:蓝猫淘气 Keywords: Motor CPU Updated: 2021/07/06
Shown is the structure of the vertical air guide drive motor and circuit . After the CPU receives the remote control signal that controls the action of the conductor plate,
the pulse signal output by the @ pin has a certain timing relationship and provides drive for the four windings of the air guide plate motor. Pulse, the motor rotates and drives
the wind deflector to swing, and the waveform of the drive signal is shown in the figure.
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- What are the challenges in designing a permanent magnet linear generator?
- Manual automatic air compressor control circuit
- Motor control circuit for starting and running without phase loss
- Temperature control circuit design and analysis
- Design and analysis of a four-bit remote control component capable of remote reset
- Design and production of no-load automatic power-off device for household power supply
- Infrared blocking alarm device
- Magnetic door and window anti-theft alarm
- Infrared detection alarm
- Homemade disinfectant circuit
- Egg heating control circuit
- Photocell trigger control circuit
- Electronic rhythm control circuit
- Infrared voice control circuit
- Assembly line outage monitoring circuit
- Circuit system composed of CPU
- CPU power supply circuit using RT9214 chip
- Internal functional block diagram of CPU power management chip HIP6302
- Interface circuit between DAC0808 and CPU
