Infrared remote control transmitter (PT2262)
Source: InternetPublisher:qoistoochee128 Keywords: Infrared remote control transmitter PT2262 pulse Updated: 2020/11/20
Shown is an infrared transmitter circuit using PT2262. In the circuit, when any one or several of S1-S4 are pressed, IC 1
(PT2262) is powered on and starts to output pulse data signals after recognizing and decoding manual instructions. At the same time, the pulse oscillator composed of IC2A
and IC2 B also starts to oscillate. The oscillation frequency can be accurately adjusted to 40 kHz: or 38 kHz by the 22 kn potentiometer. This frequency
is the infrared carrier frequency. The pulse data signal output by PT2262 is sent to IC 2 D to modulate the 38 kHz carrier wave, and then
drives the infrared light-emitting diode through the triode to emit an infrared light signal.
- How to use CAN protocol in Arduino
- The main characteristics, advantages and disadvantages of IoT protocols
- LM386 makes an AM radio
- TA7792 Medium Wave Radio Circuit Diagram
- Homemade wireless voice transmitter for telephone
- MAX23691/Q 2000-800 MHz Dual-Band Tri-Mode Transmitter
- GPS RF front-end circuit composed of MX2740
- XE1203 FSK 915/868/433 MHz Transceiver
- TXl00 ASK 1 GHz~100 MHz transmitter module
- MAX2900/2901/2902 BPSK/ASK/OOK 915/868 MHz Transmitters
- Single channel infrared remote control transmitter circuit a
- Pulse silent operation total protector circuit c
- single pulse generating circuit
- Delay characteristics of pulse conversion circuits
- Pulse boost circuitb
- Pulse LED power saving indicator light
- 10 groups of colorful light chain circuits that flash in cycles
- Automatic flush control circuit
- Pulse, triangle wave and sawtooth wave signal generator circuit using 566 03
- Infrared remote control transmitter with 60 commands
