Electronic automatic ignition circuit
Source: InternetPublisher:3228 Keywords: ignition circuit winding Updated: 2021/10/07
Shown is the automatic ignition circuit for a gas stove . When the gas stove is ignited, the 220V mains current
is limited by the 2X 47kl0 resistor and rectified by VD to charge the 0.47pLF capacitor . The voltage value is the peak value of the mains power, about
350-380V. When S1 or SZ is closed, the voltage stored in the capacitor is discharged through the primary winding
of the high-voltage transformer T
, and the secondary winding generates an induced voltage of tens of thousands of volts, which is discharged in the spark gap and ignites coal gas or liquefied petroleum gas
. The advantages of this kind of igniter are safe use, long life (up to more than 60,000 times), low power consumption
(almost no power consumption), electric spark bouquet up to 10mm, and ignition rate of 100%.
- Experiment on realizing photoelectric alarm using photosensitive devices
- Design and production of a practical electronic counting device
- Infrared detection alarm
- battery charging circuit
- Low illumination amplifier circuit
- SC3071 touch step dimming light circuit
- Chandelier brightness controller circuit using thyristor
- Touch/wireless remote control dimmer light circuit diagram
- Touch lighting switch circuit three
- Four color light circuit
- AC voltage regulator circuit
- T-type winding tap speed regulating motor
- The structure and working principle of brushless motor windingse
- The structure and working principle of brushless motor windinga
- Working principle of starting capacitor run single phase induction motor
- BX3 series AC arc welding machine circuit a
- Three-speed motor stator winding 2△-Y-△ connection method
- Two-speed motor stator winding △-△ connection method
- When the motor windings are Y-connected, the control circuit changes to low-speed operation.
- Three-phase winding motor rotor winding string resistance starting control circuit
