Photoelectric-acoustic conversion circuit a
Source: InternetPublisher:已注销 Keywords: Optoelectronics conversion circuit BSP optical signal Updated: 2021/01/24
The working principle of the circuit is as follows: This circuit connects two simple conversion circuits of electricity to light and light to electricity and sound with optical fibers for experimental demonstration
. Figure a shows the electrical ■乜 conversion circuit. The audio signal output from the headphone jack of the radio, portable music player and other audio sources is input through the socket xs, and is amplified by the VT to drive the LED to emit a light signal
modulated by the audio electrical signal to complete the electrical-to-optical conversion. The function of Ri in the circuit is to
match the input impedance of the circuit with the output impedance of audio sources such as radios and Walkmans.
Figure b shows, }electric sound conversion circuit . The light signal emitted by the LED is transmitted through the optical fiber and then received by the photosensitive diode VI. The VLS converts the
received light signal into a weak electrical signal. This electrical signal is amplified by a preamplifier composed of transistor VT and other components, and then sent to
the LM386 integrated circuit for power amplification, which drives the speaker BL to restore the sound and realize the conversion of light, electricity and sound. RP in the circuit is the volume
adjustment potentiometer.
- Example of LED AC drive circuit
- DCD-1240 multifunctional rechargeable lighting
- Use NE555 to make a lighting and sound changing circuit
- Musical doorbell without buttons
- Lighting lamp voltage stabilizing circuit (2)
- Motor speed photoelectric control circuit
- Temperature control alarm circuit
- Electronic rapid starter for fluorescent lamps
- Touch/wireless remote control dimmer light circuit diagram
- Small current anti-theft alarm circuit
- Bone hyperplasia treatment circuit
- Electric massager circuit
- Mixer built with analog multipliers
- Frequency modulator composed of NE566
- Varactor Diode Frequency Modulator
- Diode square rate detection circuit
- collector amplitude modulation circuit
- Crabo oscillator circuit
- OTL low frequency power amplifier circuit
- Second-order active band-stop filter circuit
