Sound control power saving switch circuit
Source: InternetPublisher:狂妄火龙果 Keywords: Switch circuit power saving switch BSP Updated: 2021/03/09
The power-saving switch introduced below is turned off during the day or when the light is bright, and the lights do not light up. At night or when the light is dark, the power-saving switch is in the ready working state. When someone passes near the switch, the sound of footsteps, voices, clapping, etc. can activate the power-saving switch and the light
will turn on. After a delay of 40-50s,
the power-saving switch will turn on. The power-saving switch turns off automatically and the lights go out.
(1) Guilu Working Principle The sound-controlled power- saving switch circuit consists of 7 circuits: microphone BM, sound signal amplification, half-wave rectifier, light control, electronic switch,
delay and AC switch. The circuit principle is shown in Figure 10-26 . The microphone and VT1, Ri~R, and Ci form a sound amplification
circuit. In order to obtain higher sensitivity, the Lu value of VT1 should be greater than 100, and the microphone should be selected with high sensitivity. R3 should not be too small, otherwise
the circuit is prone to intermittent oscillation. C2, VD1 and VD2, G form a rectifier circuit to convert the sound signal into a DC control voltage. Product, R5
and photoresistor RG form a light control circuit. When light shines on RG, its resistance becomes smaller and the DC control voltage attenuates greatly. VT2 cut off.
VT2, VT3 r and MA, VD3 form an electronic switch. Normally, that is, when there is light, vr2 and VT3 are cut off, there is no voltage on C4, the unidirectional thyristor
VTH is cut off, and the bulb HL does not light up. When VTH is cut off, the DC high voltage is stepped down by R9 and VD4 and then added to the upper end of C6 to charge G. When charged
to 12V, VS breaks down. Make sure the voltage on G does not exceed 15v. .
- S-Video/PAL Video Converter
- Energy-saving and environmentally friendly bicycle speakers
- DIY a portable Bluetooth speaker
- Non-contact refrigerator power-off protector circuit
- Lihe ESA-25 temperature-adjustable electronic crock circuit diagram
- Infrared remote control generator circuit diagram
- Northern brand BD-90 refrigerator circuit
- Triangle CRJ120-A multifunctional non-stick electric hot pot circuit diagram
- HA1167 is used as the third image intermediate amplifier circuit for black and white TV sets
- Water and electricity saving faucet circuit 2
- electromagnetic field sensor
- soil content measurement circuit
- High-efficiency speaker circuit for rural stage
- Particle clogging alarm circuit of wheat seeder
- Diode balanced amplitude modulation circuit
- common emitter amplifier circuit
- Second-order active band-stop filter circuit
- Color display circuit
- Motorcycle flash light circuit
- Sine wave signal generator circuit
