Ignite fluorescent lamp circuit at low temperature and low pressure
Source: InternetPublisher:三月小雨 Keywords: low voltage fluorescent lamp Updated: 2021/09/09
The method shown is to add a diode to the circuit.
When the starter is ionized, the diode conducts in the positive half cycle and acts as a rectifier, making the current
in the circuit approximately DC. For this rectified current, the impedance of the ballast is small,
which increases the instantaneous current flowing through the filament and enhances the electron emission capability. On the other
hand, due to the large current flowing through the ballast, the stored magnetic energy is also large, and
the self-inductance potential generated at the moment the starter is turned off is also high. Therefore, the lamp is easy to ignite
. If the lamp still does not light up easily after connecting the diode, the two feet of the starter should be
reversed.
The above method can not only accelerate the lighting of the lamp, but also extend the life of the lamp. The diode should be
any type of diode with a reverse withstand voltage of 400V and a rectified current of 500mA . This circuit can quickly start and light up 8W and 20W fluorescent lamps at -lo°C and 180V voltage .
- A wireless doorbell circuit
- Energy-saving and environmentally friendly bicycle speakers
- LED digital clock language time reporting circuit
- Integrated circuit sampling amplification circuit diagram
- LA5521D DC motor speed stabilizing circuit
- Northern brand BD-90 refrigerator circuit
- Electronic disinfection cabinet circuit
- Monolithic integrated circuit radio
- Dole brand BD-360A, BD-220A, BD-145A, B type refrigerator circuit
- Touch fan speed regulator circuit
- Fluorescent lamp energy-saving electronic ballast circuit
- Ignite fluorescent lamp circuit at low temperature and low pressure
- Steam iron temperature detection control circuit
- Low voltage power supply circuit of Joyoung JYC-22F induction cooker
- Ultra-low dropout linear voltage regulator circuit
- 220V direct device contactor closing circuit
- Voltage sensitive resistor for lightning protection circuit on low voltage side of distribution transformer
- Low voltage starting adjustable DC voltage stabilized power supply circuit diagram
- Low dropout voltage stabilization circuit diagram
- Ultra low voltage personal FM communication machine
