Dimming remote control circuit
Source: InternetPublisher:sigma Keywords: Remote control circuit BSP AC voltage regulating circuit pulse Updated: 2021/12/04
, if the thyristor works on barrier conduction and turn-off,
it is a contactless switch. If the trigger pulse is shifted in the flip-flop to control
the conduction angle of the positive and negative half cycles of the thyristor output, it becomes an AC voltage regulating circuit . The AC voltage regulator
works very similarly to the controlled rectifier, except that it outputs AC with positive and negative half cycles
instead of current. Thyristor AC voltage regulating circuit has replaced
mechanical voltage regulating equipment that is bulky, generates a lot of heat, is costly, and consumes a lot of copper and iron. Thyristor AC voltage regulation circuits
can be used in electric furnaces, electrolysis, and electroplating power supplies with rated currents
of several thousand amperes, as well as dimming desk lamps and speed-regulating lamps for household use . At present, in practical AC voltage regulation equipment, it is more and
more common to use bidirectional thyristors to replace two ordinary thyristors connected in reverse parallel, which greatly
simplifies the trigger circuit.
This is a home dimming desk lamp circuit. Adjust RP for stepless voltage regulation, and the light can change continuously. This circuit can also replace the lamp with other
household appliance loads, such as conveniently adjusting the speed of electric fans, small blowers, and hand drills, the temperature of electric stoves, electric blankets, electric irons, and soldering irons, and
the brightness of floor lamps and wall lamps, etc.
- Transmitter Receiver Circuit for 80 Meter Amateur Radio
- What is the basic principle of parametric amplifier?
- The production of a crystal oscillator frequency-controlled broadband FM transmitter
- MAX2360/MAX2362/MAX2364 I/Q 2000~1700 MHz/1000~800 MHz dual-band
- MGCT02 I/Q TDMA/AMPS l900/900 MHz Dual-Band Dual-Mode Transmitter
- SB-200BRX superheterodyne receiving circuit
- XEl209 70~30 kHz Ultra-Low Power CMOS Transceiver
- Radio coding transmission circuit composed of MICRF102 and PT2262
- XE1203 FSK 915/868/433 MHz Transceiver
- AT86RF211 FSK 950~400 MHz transceiver
- Motor overcurrent protection circuit
- Excellent performance household inverter power supply circuit
- Mixer built with analog multipliers
- Diode Balanced Mixer Circuit
- Frequency modulator composed of NE566
- Varactor Diode Frequency Modulator
- base amplitude modulation circuit
- Wien bridge oscillator circuit
- Parallel crystal oscillator
- Sawtooth wave generator circuit (1)
