Computer AC power monitoring circuit
Source: InternetPublisher:newlandmark Keywords: AC power computer Updated: 2020/06/20
Circuit principle: AC power supplies such as computers have large loads, and current transformers are used to detect current. It can be used to detect whether there is current in the power line and
determine its working status. LM393 is a Schmitt circuit comparator (A). After the power is turned on, the setting of the alarm time interval is completed by IC1. When binary code is input at the input
terminal (A, B, C, D), the time interval of 1C1 can be set. B and D are set to high level , and A and C are set to low level.
1C1 divides the input power frequency by 1/2". If the power frequency is 50Hz, after about 87 minutes, and when the power frequency is 60H, after about 73 minutes,
the decoding output terminal (DECODE ()UT) outputs high level , VT1 When it is on, the buzzer HA will sound, and the sound time is determined by RI-I and CH.
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Transformerless AC-DC constant current LED driver circuit
- Parallel DC regulated power supply circuit diagram
- How to use SBR to improve power conversion efficiency
- Boost drive circuit composed of RT8450
- The production of adjustable voltage-stabilized power supply composed of LM317
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Homemade Electric Bike Fast Charger
- Circuit diagram explanation: simple switching power supply circuit diagram
- STR5412 power circuit
- 24V power supply pure flat display high voltage power supply circuit diagram
- Power circuit of STR5412
- Three-phase alternating current detection circuit
- Industrial product promotion and shopping guide DC power supply circuit
- 500A-6V single-phase thyristor voltage regulating electroplating power supply circuit
- AC power supply voltage out-of-limit indication circuit
- Flash signal light circuit one b
- Transient voltage suppressor as AC power protection circuit
- AC power phase sequence indicator
