GPS receiver down converter circuit based on RF2498
Source: InternetPublisher:三月小雨 Keywords: Frequency Converter Receiver Updated: 2024/09/19
The RF2498 is a high performance CDMA tri-band/dual mode integrated LNA/mixer circuit, a tri-band LNA/downconverter. The RF2498 can be used in CDMA/cellular/PCS/GPS handsets, JCDMA/GSP handsets, CDMA modems/data cards, commercial and consumer systems, and battery-powered portable devices. The RF2498 meets IS-98 sensitivity, intermodulation, and single tone requirements. The RF2498 has a gain control of 29dB in the PCS band and 27.5dB in the cellular band. The RF2498 provides 37dB of gain for a GPS LNA/mixer application. The RF2498 uses a 3-state gain control method to meet IS-98 IMD testing. The RF2498 has a divide-by-2 pre-divider that allows the use of single-sideband or double-sideband VCOs. There is an integrated TX LO buffer on the chip. The bias current for the mixer and LNA blocks can be set by resistors off the chip. The chip adopts LCC (1eadless chip cartier)-32 package, and the chip size is 51MM×51MM
- Analysis of the reasons why bow-tie antennas are preferred over microstrip antennas for 5G antennas
- Change the frequency of the campus radio
- DKl000R OOK 315 MHz Receiver Module
- MAX2366/MAX2367/MAX2368 I/Q 2000-1700 MHz/1000-800 MHz dual-band
- Radio coding transmission circuit composed of MICRF102 and PT2262
- RF2948B QPSK 2.4 GHz Spread Spectrum Transceiver
- rfRXD0920 ASK/FSK/FM 930~800 MHz Receiver
- RF2926 AM/FMASK/FSK/OOK 915/ 868/433 MHz Dual Conversion Transceiver
- MICRF500 FSK 1000~700 MHz Transceiver
- RCV420 4~20mA Precision Current Loop Receiver
- What’s so magical about the main circuit inside the inverter?
- Phase sensitive rectifier circuit
- 27MHz simple receiver circuit with external crystal oscillator
- Senlan Almighty King SB60 inverter one to four plus soft starter
- Electrical Principle of Huifeng Inverter Circulation Pump
- Application of frequency converter in gas generator booster
- Application of frequency converter in machine tools
- Frequency converter constant voltage water supply circuit
- TV sound receiver
- Infrared two-way intercom-receiver circuit diagram
