Audio power amplifier circuit composed of LM4835/4838
Source: InternetPublisher:containsmachine Keywords: Power amplifier circuit Updated: 2024/09/18
As shown in the figure, this is the audio power amplifier circuit of LM4835/4838. The stereo left channel audio signal is input from pin 9, and the stereo right channel audio signal is input from pin 7. After amplification by the internal amplifier and 32-level DC volume control, the left channel speaker is driven from the left output (pin 12) and the -left output (pin 14) in the form of bridge output. At the same time, the right channel speaker is driven from the right output (pin 25) and the -right output (pin 23) in the form of bridge output. The outputs of pins 14 and 23 are also added to the headphone jack. The 4-pin external volume control potentiometer is used to adjust the volume (32 levels). The gain Av=2RF/Ri of the differential bridge output structure. Pin 8 is a mono buzzer input, which can generate a buzzer signal from a computer or laptop to drive a small speaker. Pin 27 is a micro-power shutdown control terminal. When pin 27 is VDD, the amplifier bias circuit is turned off, and there is no output from the headphone and speaker.
LM4835/4838 has two working modes. When the mode control pin (pin 1) is 0V, it is mode 0, which is the "line output" mode, and the amplifier gain is 1; when pin 1 is VDD, it is mode 1, and the output volume is controlled by the external volume potentiometer on pin 4. Note that pin 1 cannot be left floating. Pin 5 is the squelch control terminal. When pin 5 is VDD, the headphones and speakers are squelched and have no output; when pin 5 is 0V, the headphones and speakers output normally. The selection of the input coupling capacitor value should take into account the input frequency response (-3dB bandwidth), that is, f-3dB=1/2πRINCI. RIN is the input resistance, and CI is the input coupling capacitor.
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- Practical and high-performance preamplifier circuit
- LM4766 Dual 40W+40W Power Amplifier
- Installing a tube preamplifier in the power amplifier
- The production of 6P14 small tube amplifier
- Electronic bird repeller for crops
- Audio power amplifier circuit composed of LM4835/4838
- 1OW audio power amplifier circuit using UPC1238
- Auxiliary audio power amplifier circuit using LM4732
- LM4819 high gain audio amplifier circuit
- OTL low frequency power amplifier circuit
- Power amplifier circuit with comprehensive compensation
- Audio power amplifier circuit using TA8216A chip
- Audio power amplifier circuit using TDA2006 chip
- Integrated OCL power amplifier circuit composed of TDA2040
- Integrated OTL power amplifier circuit composed of TDA2040
- OTL power amplifier circuit
- A757 power amplifier circuit
- BTL power amplifier circuit
- LM378 two-channel audio power amplifier circuit with adjustment circuit
