Full wave and bridge rectifier circuita
Source: InternetPublisher:elleny Keywords: Bridge rectifier circuit BSP transformer Updated: 2020/11/17
The single-phase full-wave rectifier is composed of two single-phase half-wave circuits. The center tap of the secondary winding of the transformer divides U2
into two equal and opposite directions. . .
Working principle: In the positive half cycle of the sinusoidal AC power supply,
VD1 is in forward conduction, VD2 is in reverse cut-off, and
the current passes through VD1 and load resistor Ri. Return to
the tap 0 point in the center of the transformer to form a loop, and the load gets half-wave rectified
voltage and current.
In the same way, in the negative half cycle of the power supply, VD2 is turned on, VD1 is turned off, and the current flows back to the center pumping point Q of the transformer
through VD2 and RL
, and the load Ri. obtains the half-wave voltage and
current.
Repeat the above process later. It can be seen that the two diodes VD1 and VD2 of the full-wave rectifier circuit work in turns.
The voltage and current transition shapes obtained on the load are as shown in the figure.
- A very convenient small power supply circuit to share
- 220V Remote Load Monitor
- Single-power supply circuit for ISO122P/ISO124
- Transformerless AC-DC constant current LED driver circuit
- LNK304 non-isolated LED light string driver circuit
- Dynamic power supply for power amplifier controlled by thyristor
- Adjustable regulated power supply with current limiting protection
- Car power 1.5V-12V six-speed converter
- Electric bicycle battery charger circuit
- Car Audio Power Supply
- electromagnetic field sensor
- soil content measurement circuit
- Rice mill circuit
- Chicken supplementary light to increase egg production rate circuit
- Agricultural spraying and insecticide control circuit
- Diode Balanced Mixer Circuit
- Frequency modulator composed of NE566
- Wien bridge oscillator circuit
- Fault signal trip circuit
- Sine wave signal generator circuit
