Battery fast charging control integrated circuit diagram
Source: InternetPublisher:司马缸砸光 Keywords: charging control fast charging battery circuit diagram Updated: 2021/04/06
Circuit principle: The circuit provides +5V power supply voltage by a transformer, diode and voltage regulator IC7805. The battery voltage is divided by resistors R5 and R6 and then sent to the BAT end of the chip to provide a sampling voltage. The resistance of the resistor voltage divider network input to the BAT terminal should not be less than 200kΩ. When the TM terminal is grounded, the corresponding fast charge charging rate is 1C and the fast charge replenishment time is 80 minutes.
- How about the boost converter TPS61299?
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- How to Make a Soft Latch Circuit
- Energy-saving motorcycle rectifier regulator
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Constant current LED lamp driver circuit with soft start and anti-shock
- Detailed explanation of 5v charger circuit diagram
- How to use SBR to improve power conversion efficiency
- A novel and practical DC low voltage stabilized power supply
- 3~15V 10A adjustable voltage regulated power supply
- High battery life LED circuit based on GEC8310
- Programmable multi-compound fast charging circuit diagram
- Fast charging circuit (TEA1102)
- Delay circuit using battery
- New fast charging I simplified circuit
- Lithium-ion battery charging control module PS1719 circuit
- Laminated battery boost circuit
- Battery low voltage detector circuit diagram
- ICOM IC-2A battery fast charger circuit
- Charger circuit that can restore the vitality of over-discharged batteries
