Sock knitting machine fault shutdown circuit
Source: InternetPublisher:子丑寅卯 Keywords: BSP switch pulse Updated: 2021/07/10
VT1 and VT2 form a bistable state. Since the resistance values of R and R4 are different, the bias voltages applied to the base are not equal.
Therefore, after the power is turned on, VT1 is turned on, VT2 is turned off, and the relay K does not pull in, so the electromagnetic If the clutch DL is not connected to the DC power supply and
the indicator light is on, it means that the sock knitting machine is not running yet (because the machine is powered on first to run the motor and then drives the sock knitting machine to run through the electromagnetic disconnector
Press the micro switch VK and input a positive pulse to flip the trigger. VT1 is cut off; VT2 is on, K is energized, and DI. When connected to the DC power supply
, the sock knitting machine will start running and the indicator light will go out.
When a fault such as broken yarn or bad needle occurs, the process contact point is connected and the base and emitter of VT2 are short-circuited. VT2 changes from on to off,
the K relay is powered off, and the electromagnetic clutch is disconnected from the power supply. The sock knitting machine stops running and the indicator light comes on, indicating a malfunction.
After the fault is eliminated, you can press the moving switch VI (. A positive pulse is input to make the conductive tube VT1 return to the cut-off state, the VT2 fork
returns to the conductive state, and the sock knitting machine also resumes operation. If you want to knit If the knitting machine operates intermittently (i.e. starts and stops), the micro switch VR can be pressed continuously
to cause the trigger to flip over continuously, thereby achieving the purpose of intermittent operation of the sock knitting machine.
- How to design a health emergency alert device using MPU6050
- Ways to deliver more than 100A to ADAS processors
- Telephone line protection alarm circuit
- Homemade disinfectant circuit
- Electronic mousetrap circuit
- Gantry milling machine spindle control circuit
- Nine-digit key code lock circuit
- SCR control buzzer circuit
- Stapler control circuit
- G-6805 therapeutic instrument circuit
- Set timing circuit when power is on
- Chicken supplementary light to increase egg production rate circuit
- Soil water shortage prompt circuit
- Parallel crystal oscillator
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- common emitter amplifier circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Color display circuit
- Various signal generator circuits
- Sawtooth wave generator circuit (1)
