Robot wireless remote control receiving circuit
Source: InternetPublisher:笑流年 Keywords: Robot remote control reception wireless remote control receiving circuit Updated: 2020/08/11
(2) Receiving circuit The receiving circuit consists of transistor VT1 and G, cI, Ll, L2 and C3 to form a super regenerative detection circuit, as
shown in , which extracts the modulated square wave signal in the high-frequency signal received by the antenna. , sent to DJ-27 to receive dedicated circuit pin @ input amplification and comparison judgment.
The power supply of VT1 is supplied with about 5v voltage from the pin ① of DJ-27, which generates super regenerative oscillation. Adjust Ll to make the oscillation frequency close to the
carrier frequency of the transmitter and receiver, 27MHz. Under the action of the differential beat of these two frequencies, a modulated square wave signal is generated on the Yong, which first passes through G and C. R6 filters
out high-frequency components, and then couples through c6 to block DC. cl. After further filtering, the DJ-27's legs are added. After amplification, comparison and judgment inside DJ-27,
it is output by pins ⑨, ⑩ and @.
When S1 and S2 in Figure 7-16 are disconnected, no signal is transmitted. The pins ⑨~@ of DJ-27 in the receiving circuit are open circuit, Kl, K2 and K3 are not connected
, and the robot does not work. Sl is closed and the control signal is emitted. Pin ◎ of DJ-27 outputs low level, pins ⑩ and @ are open, relay K1
is closed, the Kl normally open contact connected to the robot is closed, and the robot starts to move. Same reason. S2 is closed, and pin ⑩ of DJ-27 outputs low level
. K2 is closed, pins ⑨ and ⑩ are open, and the robot moves. Sl and S2 are closed at the same time, DJ-27 pin @ outputs low level, K3 is closed,
pins ⑧ and ⑩ are open, and the robot moves.
(3) The robot drive system is the hands and feet of the robot. That is, the basic components of the movement mechanism and actuator. The design and production of the drive system
is an important part of competition robot design and practice. Its task is not only to transmit power to the robot, but also to provide accurate
motion positioning and flexible operation. It is one of the magic weapons for the robot to win, so its importance is self-evident. There are usually three ways to drive robots: electrical,
hydraulic, and pneumatic. Among them, electric drive is the most common, which can be divided into DC motor and AC motor according to the power supply method. Robot
competition rules usually stipulate the use of battery power, that is, direct current. Almost all competition robots are driven by DC motors.
- Interpretation of CAN bus driving recorder system circuit
- Ray detection circuit
- Disconnected anti-theft alarm circuit (1)
- One control three constant pressure water supply frequency conversion speed control circuit a
- Catillac luggage compartment opening circuit diagram
- Two-channel SL320 level indication circuit
- Stapler control circuit
- Commonly used oil pump motor control circuits for presses
- stapler main circuit
- Chinese learning machine disk drive interface card circuit diagram circuit
- Superheterodyne pocket radio receiving circuit
- RF remote control switch receiving circuit
- TA8141S (TV) infrared remote control receiving circuit
- BL9150 (universal) infrared remote control receiving circuit
- MC14469 (general purpose) addressable asynchronous transmit or receive circuit-02
- YN9101 dual tone multi-frequency signal remote control receiving circuit
- Contact sensor signal receiving circuit
- 50kHz FM optical receiving circuit
- 20K bit optical receiving circuit
- Remote wireless anti-theft alarm receiving circuit
