OTL power amplifier circuit in transistor radio b
Source: InternetPublisher:黄土马家 Keywords: Transistor radio power amplifier circuit BSP Updated: 2020/09/19
In the circuit shown, the voltage at point A should be half of the power supply voltage, that is, Eo/2, so it is called the midpoint voltage. When the input signal
is in the positive half cycle, it is equivalent to adding a positive bias to VT6. VT6 is on and VT7 is off. The power supply voltage
charges the output capacitor C23 through VT6 and load B (speaker ), and the charging direction is left positive and right negative. During this period, B obtains a positive half-cycle current that changes sinusoidally from top to bottom
. When the input signal is in the negative half cycle, it is equivalent to adding a positive bias to VT7, VT7 is turned on, VT6 is turned off, c23 is given
a positive bias through VT7, and cz3 is discharged through VT7 and B. During this period, the load is discharged from bottom to top. A negative half-cycle current that changes sinusoidally. As a result, since
VT6 and VT7 work in turn, a complete sinusoidal output signal is formed on load B.
In order to solve the problem of difficulty in pairing high-power complementary tubes in complementary symmetrical circuits and the need for large input power for high-power output, composite complementary symmetrical circuits
are used in many circuits .
- Echo Dot speaker intelligent control system solution
- Field effect tube amplifier circuit with beautiful sound
- Biliary duct 2A3C Class A amplifier
- Design and production of class AB headphone amplifier
- 6N5P tube direct-coupled single-ended amplifier
- Installation of electron tube differential amplifier circuit
- Inverting power amplifier circuit composed of LM4732
- LM4902 differential input audio amplifier circuit
- Auxiliary audio power amplifier circuit using LM4732
- Application of BTL power amplifier circuit composed of LM3886
- Analysis of rectifier circuit types and principles
- Pulse therapy circuit
- Smoking Cessation Circuit
- Rural vegetable greenhouse lighting circuit
- Biogas concentration detection line
- Diode Balanced Mixer Circuit
- base amplitude modulation circuit
- Wien bridge oscillator circuit
- Crabo oscillator circuit
- Voltage series negative feedback amplifier circuit
