High-precision delay timer (CD4016AE, LM307N)
Source: InternetPublisher:jikai233 Keywords: Timing Circuit Updated: 2024/08/28
As shown in the figure, this is a high-precision delay timing circuit. In the figure, Rt and Ct are timing elements, and the timing time is T=RtCt(s). In order to adjust the timing time, it can be achieved by changing Rt and Ct, but doing so will make the stability worse, so it is generally achieved by adjusting the comparison level of the comparator, that is, adjusting RV1 in the figure. This circuit is to improve the timing accuracy. It requires the use of stable comparators, capacitors, resistors, and mode switches with no offset voltage, low on-resistance, and high off-resistance. Therefore, the comparator generally uses an operational amplifier, such as LM307N; Ct uses polystyrene or polycarbonate capacitors; Rt uses metal film resistors; analog switches are best to use CMOS devices, such as CD4016AE in this circuit.
- How to choose the right level of integration to meet motor design requirements?
- How to remotely control devices using ESP8266 and LPC2148
- Tutorial for building a remote-controlled Arduino Air-Boat
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- A small improvement on the ordinary refrigerator motor starting circuit
- Squirrel cage asynchronous motor reverse braking control circuit
- Using P110C to control 6 DC motors simultaneously
- PIC microcontroller controlled remote anti-theft alarm circuit
- Car audio system anti-theft circuit
- 13 examples of electric drag control circuit diagram
- Rural fish farming control circuit
- Agricultural spraying and insecticide control circuit
- Multi-channel patrol detection control circuit b
- Remote control receiving circuit of Panasonic inverter air conditioner indoor unit control circuit
- 30s timing circuit composed of PUT lamp
- Electric blanket, rice cooker timing circuit a
- Long time timing circuit composed of 555
- Touch-type adjustable timing circuit (1)
- Darkroom exposure timing circuit (1)
