FM radio automatic search and trigger circuit
Source: InternetPublisher:黄土马家 Keywords: Trigger circuit FM radio BSP transistor Updated: 2020/04/28
Shown is an FM radio automatic search and
trigger circuit . This circuit is mainly composed of operational amplifier
yPC1167C, detector and amplifier, etc. It is used for
automatic program search circuit and broadcast station signal detection circuit.
To perform automatic program search,
when searching and tuning to a program channel, an identification signal is formed and the control circuit is notified to stop tuning
yPC1167C is a frequency identification
circuit (the aforementioned circuit) in an FM radio . (The snow pin is the audio signal output terminal,
and the ◎ pin is the level indication signal output terminal. These two signals are rectified respectively to drive the transistor Ql. . When the level of the output signal of either of these two signals
reaches a certain value after being rectified by the rectifier diode, the transistor Ql is turned on, and the collector outputs a jumping pulse
signal.
- Change the Zhongjiu receiver to 12V power supply
- LED digital clock language time reporting circuit
- Wireless charger design
- Audio vibration thawing circuit
- Hemisphere brand BC-175 refrigerator circuit
- Infrared remote control generator circuit diagram
- Triangle CRJ120-A multifunctional non-stick electric hot pot circuit diagram
- Monolithic integrated circuit radio
- Touch fan speed regulator circuit
- AM radio automatic search and trigger circuit
- Voice controlled flash LED light circuit diagram
- Analysis of rectifier circuit types and principles
- Fish pond oxygenation reminder circuit
- AC voltmeter
- Amplitude modulation circuit composed of MC1496
- Voltage-controlled voltage source second-order band-pass filter circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- High and low frequency signal generator circuit
- Fault signal trip circuit
- Sine wave signal generator circuit
