Normally closed contact anti-theft alarm
Source: InternetPublisher:睡不醒的小壮 Keywords: Contact anti-theft alarm SCR trigger Updated: 2021/03/08
The circuit principle is shown in Figure 1. SCR , R1 and AN form a thyristor trigger switch circuit; IC1, R2, VT1, VT2 and BL form an analog siren circuit. Normally, AN is oppressed by household appliances, causing its two normally closed contacts to disconnect. The SCR is blocked without a trigger signal, and the alarm does not work. When the household appliance is lifted, the AN contacts are automatically closed, and the triggering end of the SCR obtains the triggering signal from the positive pole of the power supply via R1. The SCR is turned on, and IC1 is energized to work. The siren acoustic and electrical signal output by its output end is powered by VT1 and VT2. Amplify and push the speaker to make a loud alarm sound. At this time, even if the home appliance is put back to its original place or the AN is destroyed, the alarm sound cannot be stopped. Only when the owner opens the switch S, which is installed together with the alarm and is difficult for others to find, can the alarm be released.
- Energy-saving motorcycle rectifier regulator
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Transformerless AC-DC constant current LED driver circuit
- Constant current LED lamp driver circuit with soft start and anti-shock
- The constant current source composed of two transistors can drive high power
- Parallel DC regulated power supply circuit diagram
- Principles and precautions of active discharge circuit
- Constant current charger using light emitting diode as voltage regulator
- Converting a lithium battery charging board into a constant voltage and current charger
- Importance of Voltage Supervisors and Output Topology Selection
- DC 12V to AC 100V inverter power supply circuit design
- Industrial product promotion and shopping guide DC power supply circuit
- Three-way DC-DC converter circuit
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
- CF1 (CF2) DC power supply circuit
- Recording level power supply circuit
- Household emergency power circuit 02
- Neon light high voltage power supply circuit
- Common power circuits and applications 04
