Functional block diagram of Hisense KFR-25GW-06BP inverter air conditioner outdoor unit microprocessor
Source: InternetPublisher:偷熊计划 Keywords: Microprocessor Hisense inverter air conditioner 5G Updated: 2021/10/31
Shown is the Hisense KFR-2 5G W/06BP inverter air conditioner microprocessor control circuit. Its main body is the MB90F462-SH
chip. From the picture, you can see its connection relationship with the external circuit and its main functions.
1. The work of the instruction input circuit
outdoor unit microprocessor is controlled by the indoor unit microprocessor. When the indoor unit microprocessor receives the control command sent by the user from the remote control transmitter
, the indoor microprocessor sends the control information to the outdoor unit microprocessor through the interface. The outdoor microprocessor
controls the compressor motor, fan motor, four-way valve solenoid coil and other components according to the control instructions and internal programs of the indoor unit .
2. The transmitter interface
outdoor unit microprocessor mainly controls and detects various parts in the outdoor unit. The sensor interface is the main circuit of the outdoor unit microprocessor
. The compressor temperature, input voltage value, outdoor temperature, coil temperature, exhaust pipe temperature, and current consumption value are all
parameters that the microprocessor needs to monitor at all times. Once the sensor displays abnormal information, the microprocessor will automatically shut down immediately.
- S-Video/PAL Video Converter
- Using CD4017 to form an analog pendulum circuit
- Share a home telephone recorder circuit diagram
- Audio vibration thawing circuit
- cooking timer circuit
- Relay power saving circuit 2
- Electric heating water dispenser circuit
- Rongsheng brand BCD-190 refrigerator circuit
- Touch fan speed regulator circuit
- AM radio automatic search and trigger circuit
- The German government confirms that Huawei will not be excluded from 5G network construction
- remote control receiver
- Microprocessor crystal oscillator circuit
- Microprocessor reset circuit a
- Automatic tuning control circuit
- Indoor unit microprocessor communication interface circuit
- Use 5GM168 to make novel voice-controlled music lanterns
- LS7232, S567, 5G7232 dimming control application specific integrated circuit
- 5G14 negative high voltage output regulated power supply
- Using 5G23 regulated power supply
