Digital current loop control circuit
Source: InternetPublisher:aerobotics Keywords: Control circuit DAC digital signal Updated: 2020/11/06
Shown is a floating 4~20 mA current loop control circuit at both ends . The main circuit is the DAC 0830 chip,
which is converted into an analog signal under the control of the digital signal (D), and then passes through the operational amplifier (LM10). Control VT1. Achieve control of the output current
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- In-depth analysis of energy losses in oscillation frequencies
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- How to calculate the value of capacitors in parallel?
- Simple Wired Spy Bug Circuit Built Based on IC741
- DIY a decorative lamp
- How to install the accelerometer
- Summary of knowledge points of multiplexer
- LED Night Light
- Analysis of the importance of reference voltage source
- Homemade disinfectant circuit
- Photocell trigger control circuit
- Mobile phone camera flash control circuit
- Stapler control circuit
- Infrared voice control circuit
- Interface circuit between DAC1210 and 8-bit CPU
- Chandelier control circuit
- Differential driver circuit diagram for current output DAC AD5443
- Household AC automatic voltage regulator circuit diagram
