Harmonic sound signal generator circuit
Source: InternetPublisher:红水杯 Keywords: Signal generator generator circuit multivibrator speaker Updated: 2021/03/10
Shown is a harmonic signal generator circuit. A typical multivibrator is composed of inverters 1, 2 and Ri, cl , which is used
to generate basic single tones. Inverter 3 is a buffer stage, used to excite the speaker to produce sound. Inverters 4 and 5 and VD1, R3, R4, and C2
form another square wave generator with a very low duty cycle to determine the conduction time and decay time of the harmonic circuit. VD2, C3. Rs
form a decay circuit, which is used to exponentially reduce the harmonic amplitude that changes with time.
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- An article explains the working principle of the Wheatstone bridge
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- DIY a decorative lamp
- How does RCCB work?
- How to install the accelerometer
- Touch circuit design and analysis
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- Homemade air conditioner outdoor unit shutdown indicator
- Audio high frequency generator circuit
- Sine wave signal generator circuit
- Timing pulse generator circuit
- Several improved sawtooth wave generator circuits-bootstrap circuit
- TV grid signal generator circuit
- Phase shift signal generator circuit using VMOS transistors
- Pulse, triangle wave and sawtooth wave signal generator circuit using 566 04
- Two examples of 60Hz time base signal generator circuit circuit-b
- 20Hz signal generator circuit
- Digital high frequency signal generator
