LM3420-8.4 special lithium battery charger
Source: InternetPublisher:偷熊计划 Keywords: Lithium battery charger BSP Updated: 2021/05/13
This circuit uses the LM 3420-8.4 special lithium battery charger . The circuit is simple and has excellent performance. It can quickly charge two lithium batteries. When the charging voltage reaches the rated value (4.2V for a single lithium battery), the charging current drops to trickle charging to prevent permanent damage to the lithium battery caused by overvoltage charging.
![LM3420-8.4 special lithium battery charger](http://www.eeworld.com.cn/circuit/upload/6d95722659984f0a1a983ea9a66b5af0/15315f078f37ee23375db7dde2facc4a.jpg)
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Build a simple buck-boost regulator and test it on a breadboard
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Recommended circuits for different power on times of LM4911
- Parallel DC regulated power supply circuit diagram
- Car Audio Power Supply
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Practical constant current charger-----Constant current charger
- A low-cost, high-reliability battery charger for electric vehicles
- Set timing circuit when power is on
- Ultrasonic blind pathfinder circuit
- Soil water shortage prompt circuit
- base amplitude modulation circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Differential Amplifier Circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Wireless microphone circuit
- Small current generator circuit
- Home appliance repair signal generator circuit
