Output 12V-10A power supply circuit
Source: InternetPublisher:smallembedded Keywords: Power circuit components output current switching power supply circuit Updated: 2020/02/05
It is a +12 V high current switching power supply circuit composed of L296 , and the output current can reach 10 A. The entire circuit
is small in size and uses few components .
- In-depth analysis of DC-AC converter inverter
- Fabrication of multi-cell lithium battery charging circuit
- Recommended circuits for different power on times of LM4911
- Basic connection circuit of signal and power supply composed of ISOll3
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- The constant current source composed of two transistors can drive high power
- LED Driver ZD1680
- Charging control circuit made by solar energy
- A simple positive and negative power supply circuit
- UC3842 Electric Vehicle Charger
- What are the hazards of electronic components to the human body?
- Making a 30W feedback transformer switching power supply circuit based on KA7805 chip
- Thermostatic soldering iron circuit
- Common high input impedance buffer amplifier circuit
- Humidity indication circuit composed of IH-3605
- Gosbell GRS-2001E digital satellite receiver switching power supply circuit
- via multifunctional alarm and timer (555) circuit
- Parking and incoming call alarm circuit (2)
- Board bridge type double-ended switching power supply circuit composed of TL494
- Semiconductor component withstand voltage test circuit
