Memory power controller (MAX8550) (Samsung Q35 laptop)
Source: InternetPublisher:zht24 Keywords: samsung power controller laptop Updated: 2021/03/18
Memory power controller (MAX8550) ( Samsung Q35 laptop)
Shown is a control circuit for notebook computer memory power supply. It uses MAC8550 as the control chip. This chip can also
be used in desktop computers or graphics cards and other products.
Since the power supply voltage value required by
the memory
circuit has a high accuracy (+2.5 V), and the battery supply voltage accuracy is low and will decrease with time, the working accuracy and voltage stability of the voltage stabilizing circuit are both poor. The requirements are higher.
The MAX8550 also uses pulse width modulation (PWM), and outputs a set of pulse width modulation signals with opposite phases from the DH terminal and the DL terminal.
Drive Q1 and Q2 respectively. Make Q] and Q2 work alternately to change the DC voltage of the battery into a high-frequency pulse voltage. Finally, after LC filtering,
the DC regulated current is output. The output current of this circuit can reach 12A.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- Single-power supply circuit for ISO122P/ISO124
- Op amp power supply decoupling bypass measures
- Miniature polarity reversal power supply using MAX1721
- Homemade low-power UPS
- 3~15V 10A adjustable voltage regulated power supply
- Electric bicycle battery charger circuit
- Mc34063 MP3 Switching Charger
- Car Audio Power Supply
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Switching power supply circuit composition and detailed explanation of each part (1)
- DC 12V to AC 100V inverter power supply circuit design
- Portable device charging power circuit design
- Power supply circuit design optimized for digital light projectors
- Warm current power circuit a
- Timing switch AC power circuit
- led drive power circuit
- Common power circuits and applications 05
- 25Hz ring current power supply circuit
