Circuit diagram of miniature wireless alarm transmitter
Source: InternetPublisher:两手空空 Keywords: transmitter circuit diagram wireless alarm Updated: 2020/09/21
Today I will share with you the circuit diagram of a miniature wireless alarm transmitter . The circuit of this alarm is simple. By changing the sensor at the transmitting end and setting the address code and status code of VD5026/5027, the uses of this alarm can be greatly expanded (such as multi-channel alarm, data transmission, etc.).
As shown in the figure below, a small magnet and a normally closed contact reed switch E form an intrusion detector. The small magnet is installed on the door leaf of the storage room. The reed switch E is close to the small magnet and installed on the opposite door frame. Normally, the door is closed. Since the small magnet is close to E, the two normally closed contacts inside E are disconnected by external magnetic force. The micro transmitter does not work due to no power supply. Once a theft occurs, the small magnet will move away from E with the door leaf, and E will lose the effect of the external magnetic field. Its two internal contacts will close by relying on its own elasticity. When the micro transmitter is powered on, it will immediately send out a coded alarm signal.
![Circuit diagram of miniature wireless alarm transmitter](http://www.eeworld.com.cn/circuit/upload/05e30da1966cd60f0284d8b957daed4e/7e04c401097f1598707921b1cf44037f.jpg)
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Energy-saving motorcycle rectifier regulator
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- LED rechargeable flashlight circuit diagram
- Charging control circuit made by solar energy
- Homemade low-power UPS
- MIC4680 constant current charger
- Circuit diagram explanation: simple switching power supply circuit diagram
- Importance of Voltage Supervisors and Output Topology Selection
- Switching power supply circuit composition and detailed explanation of each part (1)
- Power supply circuit design optimized for digital light projectors
- Power circuit with smoothing filter capacitor
- Three-way DC-DC converter circuit
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- Timing switch AC power circuit
- Super Class A power amplifier power circuit
- Low voltage adjustable reference power circuit
- Music power circuit
